martyn20
Jul 03, 2014Aspirant
RN104 New Volume
Could not see this particular problem, forgive me if I have missed it and started another thread for nothing. I have a new RN104, I started it for the first time with a new 4TB disk and followed the ...
- Jul 03, 2014With RAID-1 the two disks are mirrored, so adding the second drive does not add capacity - it adds redundancy. If you hot-insert a third 4 TB drive the space will increase to 7.2 TiB, and the NAS will switch to RAID-5. You still have redundancy which protects against a single drive failure.
If you wanted jbod (no RAID) then you should start over with another factory reset (with only one drive installed), switch to FLEXRAID/JBOD, and hot-insert the second drive.
Adding a new disk to the RN104 is easy, I am puzzled by your comment on "not simple to add more disks".
berillio
Dec 01, 2014Aspirant
thanks mdgm. it has just done 1h now, I did put a camcorder on it . . I'll report tomorrow, it's 2:30am in the UK
