freakout
Oct 19, 2018Star
RN104: "No Volume Exists" error
Hello all,
Came home from a trip this weekend to find that I could not copy files to my ReadyNAS from my PC. I assumed the ReadyNAS just needed a reboot, and rebooted it. Upon rebooting I found...
freakout
Oct 19, 2018Star
Thanks Stephen. I'm actually running ReclaiMe right now and it can see all the files on the drives as I individually connect them to my PC, although the folder names for many of them are quite jumbled.
Since the cost of a ReclaiMe license is basically equivalent to what it would cost me to have Netgear attempt a fix, I think I'm going to have to just rebuild everything myself.
This is quite disappointing though - it just seemed to happen completely out of the blue. Are there any known methods for checking why/how this happened? Aside from an issue with a firmware update three years ago, my ReadyNAS has been issue-free and I'd like to think it will stay that way.
Oct 19, 2018Guru - Experienced User
Others here have also reached that conclusion, and most have reported good results.
After you offload the files, you could reinsert the disks in the NAS and download the log zipfile. Look at disk_info.log and look at the SMART statistics there. System.log, kernel.log, and dmesg.log might have some clues. You could PM a netgear mod here and ask if they are willing to review your logs. It's ok to post snippets of your logs publicly, but don't post links to your full log zip file.
RAID isn't enough to keep your data safe. Personally I have a backup plan in place for my data, so I am always able to restore the data from a backup with minimal data loss.
