tom_nguyen_2004
Jun 05, 2023Aspirant
RN104 No volume exists
Hi, I have a Readynas RN10400 with firmware version 6.10.8 It has 3 x Seagate NAS ST3000VN000 and 1 WD Red NAS disk drives configured with X-RAID but since issue the system shows RAID 5 and zer...
- Jun 07, 2023
tom_nguyen_2004 wrote:
I use Windows and have no experience using Linix commands, however if you can guide me with the force mount command i should be able to work it out. Really appreciate you assistance.
First, you do need to be careful, as mistakes in typing can cause more damage. Note that linux generally uses / for file paths, and not the \ that Windows uses.
If you never changed the admin password of the NAS (default is password), you will need to change it to something else first.
Then log in - you can enter "ssh root@nas-ip-address" in the windows command line if you are using windows 10 or windows 11. Use the real IP address of course. You will get a fingerprint query from Windows (don't recall the exact text), tell it to save the SSH fingerprint. This will open up a black text console window on the PC for command entry. Use the NAS admin password when prompted by the NAS.
Then enter these commands:
mdadm --assemble --really-force /dev/md127 /dev/sd[abcd]3 mount /dev/md127 /dataYou might get an error from the first command - I'm specifying all 4 disks, since I am not sure what three device letters are currently assigned to the other three.
If this doesn't work, copy/paste the console output in your reply so I can see what's going on.
If this does remount the data volume, then you should immediately make a backup.
Please also run this command from ssh, and copy/paste the output in a reply:
cat /proc/mdstatYou should see something like this:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md127 : active raid5 sda3[5] sdd3[7] sdc3[6] sdb3[4] 17567012352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] md1 : active raid10 sda2[0] sdc2[3] sdd2[2] sdb2[1] 1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU] md0 : active raid1 sda1[5] sdd1[7] sdc1[6] sdb1[4] 4190208 blocks super 1.2 [4/4] [UUUU]I'm interested in md0 and md1 - there was something not right with md0 in particular in your logs. It should be mirrored on all disks, but it seemed to be only installed on one. We should fix that also, but only after you have a backup of the data.
tom_nguyen_2004
Jun 06, 2023Aspirant
I have enabled the SSH on the NAS now, initially when i tried to enable it, popup says that it can not be enabled, did it about 3 times and it still contiunued with the popup error. i rebooted the NAS and logged back into the admin UI and SSH shows it is active, however disk #4 now seems to be dead as it is not showing up in the volume page. the slot is just black.
Jun 07, 2023Guru - Experienced User
cat /proc/mdstat
