cmjcf
Aug 22, 2026Aspirant
RN104 on 6.10.10 kernel location
Where on the filesystem should the kernel be located? My device has a current uptime of around 140 days, and I may need to restart it. Netgear-supplied package kernel-image is at 4.4.218-610090...
Aug 22, 2026Guru - Experienced User
cmjcf wrote:I have been able to install the upstream Debian package linux-image-marvell, which appears to be the kernel required here if none is otherwise available, but I am not sure if that has properly configured the bootloader. Now, the only files in /boot are the kernel, config and initrd from this kernel.
Why are you doing this? Are you trying to use a newer kernel?
You shouldn't have needed to install anything (and you might have created an issue by doing so).
cmjcf
Netgear-supplied package kernel-image is at 4.4.218-610090002, but dpkg -L kernel-image shows that this package contains no files and it has no dependencies, so I am concerned that if the system needs to be rebooted (e.g. because of power failure longer than the UPS can sustain it) it will not come back up.
- StephenBAug 22, 2026Guru - Experienced User
Totally not the case. There was no need to install anything. It would be totally crazy for Netgear to provide a system that could never be rebooted.
But whatever you installed might well create problems when you restart. So I suggest backing up the data, and then trying to restart.
