WiredRacing
Mar 17, 2019Aspirant
RN104 on 6.9.5 - SMB Doesn't Load (problem in smb.conf)
So I recently upgraded the firmware from 6.7.5 to 6.9.5 and also did a drive upgrade, exporting a volume, re-importing it and various other things that have led to several reboots of the NAS. But bas...
JohnCM_S
Mar 19, 2019NETGEAR Employee Retired
Hi WiredRacing,
2019/03/17 04:00:22.733065, 0] ../lib/param/loadparm.c:1121(lp_set_enum_parm)
WARNING: Ignoring invalid value '(null)' for parameter 'smb encrypt'
That is just a warning and should not be the reason the NAS does not start the SMB. It says it is ignoring the invalid entry, which then defaults to the default smb.conf configuration.
There could be another reason the SMB does not load. You may download the logs and then provide it to us so we can check. You may upload it to Google Drive then PM me the download link.
