WiredRacing
Mar 17, 2019Aspirant
RN104 on 6.9.5 - SMB Doesn't Load (problem in smb.conf)
So I recently upgraded the firmware from 6.7.5 to 6.9.5 and also did a drive upgrade, exporting a volume, re-importing it and various other things that have led to several reboots of the NAS. But bas...
JohnCM_S
Mar 19, 2019NETGEAR Employee Retired
Hi WiredRacing,
2019/03/17 04:00:22.733065, 0] ../lib/param/loadparm.c:1121(lp_set_enum_parm)
WARNING: Ignoring invalid value '(null)' for parameter 'smb encrypt'
That is just a warning and should not be the reason the NAS does not start the SMB. It says it is ignoring the invalid entry, which then defaults to the default smb.conf configuration.
There could be another reason the SMB does not load. You may download the logs and then provide it to us so we can check. You may upload it to Google Drive then PM me the download link.
JohnCM_S
Mar 22, 2019NETGEAR Employee Retired
Hi WiredRacing,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
