ghailoo
Jun 05, 2016Aspirant
RN104 OS 6.5.0 Stuck at Booting 99%
Hi All, I have been using my ReadyNAS 104 with OS 6.5.0 for awhile now. Yesterday I decided to reboot the ReadyNAS after shutting off PLEX. After the reboot the system is stuck at "Booting... 9...
- Jun 14, 2016
I'm also seeing some other signs of database trouble - entries like:
Jun 05 12:41:22 GYHL2 readynasd[4253]: DB sanity check failed! Trying backup readynasd_2016_06_04_145137.db
But I can't think of much you can do about this, especially without access to the web ui. If you have a backup, then a factory reset (and reload data from the backup) might be the best option. Painful, but certain. Of course you can also go with support.
Jun 06, 2016Guru - Experienced User
It could be a failing disk, so maybe start in disk_info.log
- ghailooJun 06, 2016Aspirant
Hi Stephen,
Thank you for you reponse. I have checked the disk log file and found nothing.
I booted into "Disk check" and "Memory Check" and both looked ok (I am not 100% sure though)
The last operation I performed on the NAS was uninstallation of PLEX. In the install_debpkg.log file it says :
The following packages will be REMOVED:
plexmediaserver-ros6-binaries*
0 upgraded, 0 newly installed, 1 to remove and 33 not upgraded.
After this operation, 251 MB disk space will be freed.
(Reading database ... 34076 files and directories currently installed.)
Removing plexmediaserver-ros6-binaries ...
Purging configuration files for plexmediaserver-ros6-binaries ...
dpkg: warning: while removing plexmediaserver-ros6-binaries, directory '/apps/plexmediaserver' not empty so not removed
Processing triggers for libc-bin ...
Success purge plexmediaserver-ros6-binariesWhat would be the next recomended step to check for or to do ?
Thank you
I took the liberty and sent out the log files
