ghailoo
Jun 05, 2016Aspirant
RN104 OS 6.5.0 Stuck at Booting 99%
Hi All, I have been using my ReadyNAS 104 with OS 6.5.0 for awhile now. Yesterday I decided to reboot the ReadyNAS after shutting off PLEX. After the reboot the system is stuck at "Booting... 9...
- Jun 14, 2016
I'm also seeing some other signs of database trouble - entries like:
Jun 05 12:41:22 GYHL2 readynasd[4253]: DB sanity check failed! Trying backup readynasd_2016_06_04_145137.db
But I can't think of much you can do about this, especially without access to the web ui. If you have a backup, then a factory reset (and reload data from the backup) might be the best option. Painful, but certain. Of course you can also go with support.
ghailoo
Jun 06, 2016Aspirant
Hi Stephen,
Thank you for you reponse. I have checked the disk log file and found nothing.
I booted into "Disk check" and "Memory Check" and both looked ok (I am not 100% sure though)
The last operation I performed on the NAS was uninstallation of PLEX. In the install_debpkg.log file it says :
The following packages will be REMOVED:
plexmediaserver-ros6-binaries*
0 upgraded, 0 newly installed, 1 to remove and 33 not upgraded.
After this operation, 251 MB disk space will be freed.
(Reading database ... 34076 files and directories currently installed.)
Removing plexmediaserver-ros6-binaries ...
Purging configuration files for plexmediaserver-ros6-binaries ...
dpkg: warning: while removing plexmediaserver-ros6-binaries, directory '/apps/plexmediaserver' not empty so not removed
Processing triggers for libc-bin ...
Success purge plexmediaserver-ros6-binaries
What would be the next recomended step to check for or to do ?
Thank you
I took the liberty and sent out the log files
Jun 07, 2016Guru - Experienced User
If you don't get a response from Netgear on the logs, you should contact support.
- mdgm-ntgrJun 13, 2016NETGEAR Employee Retired
Your logs are flooded with messages regarding the iTunes service suggesting the database for that may be corrupted.
- StephenBJun 14, 2016Guru - Experienced User
