ghailoo
Jun 05, 2016Aspirant
RN104 OS 6.5.0 Stuck at Booting 99%
Hi All, I have been using my ReadyNAS 104 with OS 6.5.0 for awhile now. Yesterday I decided to reboot the ReadyNAS after shutting off PLEX. After the reboot the system is stuck at "Booting... 9...
- Jun 14, 2016
I'm also seeing some other signs of database trouble - entries like:
Jun 05 12:41:22 GYHL2 readynasd[4253]: DB sanity check failed! Trying backup readynasd_2016_06_04_145137.db
But I can't think of much you can do about this, especially without access to the web ui. If you have a backup, then a factory reset (and reload data from the backup) might be the best option. Painful, but certain. Of course you can also go with support.
mdgm-ntgr
Jun 13, 2016NETGEAR Employee Retired
Your logs are flooded with messages regarding the iTunes service suggesting the database for that may be corrupted.
Jun 14, 2016Guru - Experienced User
