Pstreicher
Jan 12, 2016Luminary
RN104 Procedure to swap enclosure. #26221873
Have received a new RN 104 enclosure today after creating a ticket on 12/22/2015 for lcd display digits are turning white starting from left side of the display. No instructions were given to me on h...
- Jan 28, 2016
Jenn, I will keep the FedEx tracking numbers handy on the coffee table by the computer. Once it reaches NetGear I'll be putting in a call for verification that no charge(s) have been made on my credit card without my knowledge. Thanks for staying in touch here. Here's some pictures of my handy work yesterday. Gives you an idea of what's inside these cases.
The defective LCD display module above and below.
Take a look at this beautiful surface mount technology. Notice there is a change in components in the next two close-ups.
Note the '4R7' components. There appear to be either coils or resistors. May be a combination and part of the power regulation.
These look like metalic and the previous, a plastic coating or something. I just thought this was interesting.
Hey, do you think Netgear could use another repair tech? I work cheap! ;)
AlexPe
Jan 12, 2016NETGEAR Expert
Hi Pstreicher,
Yes, all of the instructions you listed are accurate.
Make sure both units are off
Place the disks in the new chassis in order from left to right.
When you boot the system it will update the firmware to match what ever is on the disks.
This process should not take very long.
The only other item I would say is to make sure critical data is backed up other than that should be good to go.
AlexPe
Community SME
Pstreicher
Jan 20, 2016Luminary
I received what may be an automated email asking me if I got a solution and to mark this thread solved if so.
No! It has been five days now and am still waiting on the 2nd replacement enclosure to be delivered.
I'm sitting here with this 1st replacement enclosure, not sure what to do with it as I wasn't told anything over the phone when the agent took my credit card information as colateral, for what I assume we were talking of geting a 2nd replacement sent to me. I'm getting a bit fed up here now with all of this. Should I just pack the 1st damaged in shipment enclosure in the package it came in with the pre-addressed label to Netgear and be done with it? I don't want to mess anyting up so here I sit not knowing what to do. I'm wondering if it is the out-sourced customer service that is at fault for not telling me what I should do with this damaged enclosure I received. I am assuming that when, and if I ever get this 2nd replacment unit that maybe there will be instructions some place that will tell me to return the 1st damaged enclosure back to Netgear and then to return my enclosure with the faling LCD display in the box that the 2nd enclosure came in. I guess I'll wait until I get another email telling me that in 3 days the case will close if I don't respond and then type up another reply asking for someone to please call me and tell me what the hell is going on.
