chri6020
Dec 31, 2014Aspirant
RN104 randomly freezing since update to 6.2.0 (curr. 6.2.2)
Hello, since i upgraded my RN104 to OS 6.2.X the NAS randomly freezes every couple of days (no front-end, no SSH and no reply to pings). The only way to get access again to the RN104 is disconnecti...
mdgm-ntgr
Jan 13, 2015NETGEAR Employee Retired
tommylommytommy I notice you have two WD Green disks installed which are not on the compatibility list.
Two of your disks, one of the WD RED disks and also your WD20EARS have huge Load Cycle Counts.
Perhaps the issue you are facing is disk related?
Are you able to power down, remove your disks (label order), connect them to your PC and test them using WD Data LifeGuard Diagnostics?
- Jan 17, 2024Anonymous
