lwilbur
Mar 27, 2016Aspirant
RN104 "Retry Startup" problem
Getting "Retry Startup" on RN104 with 4 - 2T Seagate drives in RAID 10 mode that has been in this configuration since Aug 2013. Unit blinking green power button and will only power down by pulling p...
lwilbur
Mar 29, 2016Aspirant
After several tries got log download using RAIDar 6.1. Logs sent. Thanks for the help and look forward to a solution
mdgm-ntgr
Mar 29, 2016NETGEAR Employee Retired
Disk 1 has failed. I have PM'd you the serial number of this disk.
Also one of the databases is corrupt.
Do you have a backup?
- lwilburMar 29, 2016Aspirant
mdgm: Thanks for the response and info.
No, do not have a recent backup. As I noted, am still able to access the files on the drive and have pulled off the majority of the important files.
Can replace failed disk you identified. Suggestions on how to deal with the corrupt database? When I put in new disk will the database be rebuilt and the unit reboot correctly?
- mdgm-ntgrMar 29, 2016NETGEAR Employee Retired
I have sent you a PM.
- mdgm-ntgrApr 03, 2016NETGEAR Employee Retired
Should now be fixed.
The particular issue you ran into that caused the "retry startup" error is addressed in the next firmware release (6.5.0). Note that there are other possible causes of this error.
