lwilbur
Mar 27, 2016Aspirant
RN104 "Retry Startup" problem
Getting "Retry Startup" on RN104 with 4 - 2T Seagate drives in RAID 10 mode that has been in this configuration since Aug 2013. Unit blinking green power button and will only power down by pulling p...
rgpjanssen
May 05, 2016Initiate
Hello, I had the same problem.
When i powered my NAS on, it says booting and after a few minutes he says only "RETRY STARTUP",
i can't power off the NAS normaly, i was forced to pull the power out of it.
After i put the power on, it came again with "RETRY STARTUP"
I pulled the plug again and removerd all HDD's and replace thos HDD's with an other HDD who has not been in my NAS.
I did install the NAS again but now only on that ONE HDD.
After the install was finished, i did a firmware update to the last update.
After the Firmware update was done, i was able to power off the NAS like it should be.
After the NAS was powered down, i removed that ONE HDD, and put my 4 HDD's back in to the NAS, and rebooted it again.
Now everything was back to normal, only the Firmware was now updated but everything else was just fine again.
