borgchick's avatar
borgchick
RN104 says inactive volume
I found my RN104 frozen a few days ago.  Last email I saw from it was that a balance had started.
When I found it frozen, it was unreachble via ssh, or even responding to ping.  Power button had no effect.  I had to pull the plug.
Upon restart, it froze again, during boot, at 39%.  I had to pull the plug again.
Next restart, it finishes booting, but the raid array is gone.  It sees all 4 drives, all are reported as healthy.
Log into admin, and it says "Remove inactive volumes to use the disk. Disk #1, 2, 3, 4."
What do I do?  I see some posts suggesting factory defaulting it, but I just don't want to do anything that might make the situation worse.
dmesg log at https://dumptext.com/6gt64u7v/raw/
Thanks in advance!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I can see you're on old firmware (don't update the firmware with the NAS in this state).
    I can also see this in your dmesg.log
    [   17.575851] BTRFS: device label 0e343298:data devid 2 transid 146384 /dev/md126
    [   18.381179] BTRFS (device md126): bad tree block start 11637558493067324903 17973882290176
    [   18.382106] BTRFS (device md126): bad tree block start 11637558493067324903 17973882290176
    [   18.382157] BTRFS: failed to read tree root on md126
    [   18.430349] BTRFS: open_ctree failed
    Have you tried booting into volume read-only mode?
    Is your backup up to date?
    A factory default (wipes all data, settings, everything) is fine to do if you have a good up to date backup that you can restore from afterwards.
    If not, you may wish to contact support if booting into volume read-only mode doesn't resolve the problem.
    • borgchick's avatar
      borgchick
      So I tried the readonly mode, no effect.  Same error in dmesg.
      I did a bit more poking around.  So each disk has 4 partitions, and if I use mdadm --examine on each set, there appear to be 4 raid set ups
      /dev/sd*1 is raid 1
      /dev/sd*2 is raid 6
      /dev/sd*3 is raid 5
      /dev/sd*4 is raid 5
      If I look at the raid states:
      root@nas:~# mdadm --examine /dev/sd*1|grep "State"
                State : clean
         Array State : AAAA ('A' == active, '.' == missing, 'R' == replacing)
                State : clean
                State : clean
                State : clean
      root@nas:~# mdadm --examine /dev/sd*2|grep "State"
                State : clean
                State : clean
                State : clean
                State : clean
      root@nas:~# mdadm --examine /dev/sd*3|grep "State"
                State : clean
                State : clean
                State : clean
                State : clean
      root@nas:~# mdadm --examine /dev/sd*4|grep "State"
                State : clean
                State : clean
                State : clean
                State : clean
      So everything is clean.
      But if I try to mount the file system, even in degraded mode, it fails:
      root@nas:~# mount -t btrfs -o degraded /dev/md127 /var/recover/
      mount: wrong fs type, bad option, bad superblock on /dev/md127,
             missing codepage or helper program, or other error
             In some cases useful info is found in syslog - try
             dmesg | tail or so.
      root@nas:~# mount -t btrfs /dev/md127 /var/recover/
             dmesg | tail or so.
      If I look at dmesg, it is the btrfs ctree error:
      [ 3847.552053] BTRFS (device md126): bad tree block start 11637558493067324903 17973882290176
      [ 3847.552446] BTRFS (device md126): bad tree block start 11637558493067324903 17973882290176
      [ 3847.552481] BTRFS: failed to read tree root on md126
      [ 3847.580455] BTRFS: open_ctree failed
      [ 3852.027911] BTRFS (device md126): bad tree block start 11637558493067324903 17973882290176
      [ 3852.028306] BTRFS (device md126): bad tree block start 11637558493067324903 17973882290176
      [ 3852.028342] BTRFS: failed to read tree root on md126
      [ 3852.070223] BTRFS: open_ctree failed
      So, it seems to me that this is some sort of btrfs corruption issue.
      btrfs fi show
      Label: '0e343298:data'  uuid: 92ecd2e0-45da-425b-87a8-0f626e5ef889
              Total devices 2 FS bytes used 5.04TiB
              devid    1 size 2.71TiB used 2.53TiB path /dev/md127
              devid    2 size 2.73TiB used 2.54TiB path /dev/md126
      Now I don't know why there are two md raid set ups, from other digging (dry run) I see md127 thinks device 2 is missing, whatever that is, is that the second drive? the second raid set (/dev/md126?)
      oot@nas:~# btrfs restore -F -i -D -v /dev/md127 /dev/null
      checksum verify failed on 17973882290176 found 28166D04 wanted 8B8262A2
      checksum verify failed on 17973882290176 found 46A24E6E wanted 51485848
      bytenr mismatch, want=17973882290176, have=3707086136388172086
      Couldn't read tree root
      Could not open root, trying backup super
      warning, device 2 is missing
      Any suggestions?
      I do have a backup, but I really would like to take this as a learning opportunity.
      Thanks!
        mdgm-ntgr
        As it's on multiple arrays a
        # btrfs device scan
        is needed before attempting to mount the data volume. However with the system booted normally the system would have already run that command.
        If your backup is up to date I'd follow the suggestion I gave for that scenario in my previous post.
ProSupport for Business
