HolgerGT86
Apr 08, 2020Guide
RN104 shutdown because disks exceed safe temperature
Hello, I'm using a RN104 at firmware level 6.10.3. The ReadyNAS is equipped with 4 times Hitachi HUA721010KLA330 1TB SATA drives, all 4 drives building one RAID5 X-RAID volume. Today the RN104 sh...
Apr 08, 2020Guru - Experienced User
HolgerGT86 wrote:
I would be happy to receive some advice how to proceed.
It's possible that one disk is overheating (and raising the temp of the adjacent disk). Have you looked at the temperatures of disk 1 and disk 4?
I'd start by powering down the NAS, and then confirm that disks 2 and 3 are in fact hot, and also see how disks 1 and 4 compare.
Maybe also connect the disks to a PC, and run the vendor diagnostics on each one. You can monitor the temps using any tool that supports smart stat gathering (Acronis Disk Monitor is one of several such tools). This would confirm that the disks are still working properly, as well as giving you some idea of the temperature rise during the test. Ideally use a USB/SATA adapter. A dock is ok too, but of course it would reduce the air flow around the disk. If one disk is spiking more than the others, then you might just need to replace that drive.
WD's Lifeguard software should recognize the disk, and let you run the non-destructive long test.
Another test you could try is to swap disks 1 and 2, and also swap 3 and 4. Do this with the NAS powered down, and label the disks by their original slot number. The system should be able to mount the volume normally (even in the different order). Then look at the temperature pattern, and see if the hottest disks are still in the center slots, or if they are shifting to the outside.
HolgerGT86
Apr 08, 2020Guide
Hello Stephen,
many thanks for your fast response!
I confirm that the disk were really warm as the air coming out of the RN104 was really warm. When I powered the RN104 again ... some minutes after the shutdown ... the inner disks were at about 60°C and the outer disks at about 50-54°C.
Swapping the disks would be an option I can try. Connecting a PC may be an issue as I use Apple at home.
What about the coexistence with the defrag processes? I'm using the RN104 as backup device only (about 99%), maybe I'm using it to share single files. Never had an issue with that.
I'm running defrag, scrub, balance and disk test maintenance on a regular base, but the issue only occured directly after defrag so far.
Is it possible that, when the parallel running defrag ends, the fan controlling process is halted, too? By chance I mean.
Any way to find out why the defrag is started twice?
Any way to find out if the fan controlling process is in trouble?
- StephenBApr 08, 2020Guru - Experienced User
Normally the disks will get hotter under heavy use. So if the defrag (or any other task) has a lot of work to do, I'd expect a temperature rise. But the NAS fan control should be enough to prevent the actual overheating.
It is conceivable that the fan got damaged when you cleaned it. You should definitely be hearing the fan kick into high gear as the temperature goes up. Maybe move the NAS to a new spot where that would be easier to hear??? You should also be able to feel the air flow, esp. when it ramps up.
X86 NAS (RN300 series and up) do have performance graphs that include SYS and CPU temps. But not the RN100 and RN200 familes.
If you enable ssh, then smartctl might give you some temperature history
root@NAS:~# smartctl -x /dev/sda smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.190.x86_64.1] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === ... SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/65 Celsius Min/Max Temperature Limit: -40/70 Celsius Temperature History Size (Index): 128 (17) Index Estimated Time Temperature Celsius 18 2020-04-08 09:18 35 **************** ... ..(126 skipped). .. **************** 17 2020-04-08 11:25 35 **************** ...
This might not be available with your disks though.
You can also get the current temp
root@NAS:~# smartctl -a /dev/sda | grep Temperature_Celsius 194 Temperature_Celsius 0x0002 203 203 000 Old_age Always - 32 (Min/Max 13/45) root@NAS:~# smartctl -a /dev/sdb | grep Temperature_Celsius 194 Temperature_Celsius 0x0002 185 185 000 Old_age Always - 35 (Min/Max 14/48) root@NAS:~# smartctl -a /dev/sdc | grep Temperature_Celsius 194 Temperature_Celsius 0x0022 119 105 000 Old_age Always - 33 root@NAS:~# smartctl -a /dev/sdd | grep Temperature_Celsius 194 Temperature_Celsius 0x0022 121 108 000 Old_age Always - 31 root@NAS:~#
It's easy to redo these commands w/o retyping them - you use the up arrow on your keyboard to see the previously entered commands, and then press enter to re-execute it again.
BTW, you might find that the disks will run a bit cooler if you open the front door. That's not a fix of course.
- HolgerGT86Apr 08, 2020Guide
StephenB wrote:BTW, you might find that the disks will run a bit cooler if you open the front door. That's not a fix of course.
I did that already after bringing the RN104 back up. I closed it again because now the temperature is stable again. But thanks for letting me know!
I checked the fan and it is running fine. The speed control is working as expected - now. The disk test just completed successfully. Temperature was about 40°C +/- 6°C all the time. The fan running at 27xx/ 3233 RPM.
The issue is that I had no chance to control the fan speed at time of issue so far.
This is, because I notice there's an issue when I receive the eMail that the disks are getting warm. Warning level and shutdown are all happening within 60 seconds, so no chance for me to run down into the cellar to check what's going on. When I'm down in the cellar the RN104 is already powered off.
I scheduled another defrag for tomorrow, trying to recreate the issue.
I'll try of the commands you provided. Maybe I can get a script running to monitor temperature and fan speed during the defrag.
