Neccros
Dec 09, 2015Aspirant
RN104 Slow UI after 6.4 update
I have a RN102 and two RN104s. When I updated them to 6.4.0, two of them work perfect and the UI through the web browser is snappy and responsive. My other 104 seems really sluggish and when you cli...
Dec 09, 2015Guru - Experienced User
Likely btrfs-cleaner is finding a lot to do on the slow RN104. It should complete eventually, but if you have ssh enabled, you can cancel it.
Though I think I'd try a manual 6.4.1 install first. Download it from the website, extract the image from the zip file, and install it from system->settings. If you have the antivirus service enabled, turn it off before you upgrade. There's a performance issue there, which Netgear is working on.
Neccros
Sorry... I didnt get a word you just said... LOL
- StephenBDec 09, 2015Guru - Experienced User
Tell me what step below you don't understand
(a) disable the antivirus service on the RN104 if it is running.
(b) download 6.4.1 zip file for arm from Negear's web site.
(c) extract the 6.4.1 image from the zip file
(d) go into the web ui, choose system->settings, and click the "install firmware" button under "manual install firmware"
(e) choose the 6.4.1 image file when prompted, and follow the rest of the steps it prompts for.
- NeccrosDec 09, 2015Aspirant
I did all this... and I never used the Antivirus... This is why I am posting here... I figured going from 6.4.0 to 6.4.1 would fix the issue but it didnt
Your initial post left the impression that the slow NAS was running 6.4.0, and nothing was said about antivirus.
One suggestion (just posted on a different thread) is to install 6.4.1 manually again on the slow NAS. That poster found that doing so solved his performance problem.
