hamish_mclean
Jun 04, 2016Aspirant
RN104 stuck at 99% (mysql.service) following 6.5 upgrade and USB Recovery
HI Keep my ReadyNas firmware updated when each release come out. Folliwing upgrade to 6.5 and removal of the Surveilance and SMB apps it will only boot to 99%. It then only rebooted to 95%, then ...
- Jun 08, 2016
No account called backup.
However, have added a share called backup - and removed it
Resynced/rebooted NAS
Reboored PC
IT's gone !
Interestingly, until I rebooted the PC, I had no access to the other shares having rebooted the Nas ?
Jun 08, 2016Guru - Experienced User
Is there a account named "backup" configured on the NAS?
hamish_mclean
Jun 08, 2016Aspirant
Reboored PC
IT's gone !
- StephenBJun 08, 2016Guru - Experienced User
Is it possible that on the windows system you had the shares enabled for off-line access?
- hamish_mcleanJun 08, 2016Aspirant
Windows had mapped several drives including one called "Backup" (capital B) but, after resetting, none of the mapped drives were accessable including the default shares which had previsould been mapped - no big issue, just remapped them.
But there was nothing set to offline nor was there a mapped drive called 'backup' (lowercase b)
- StephenBJun 09, 2016Guru - Experienced User
There is a bit of a mystery here, but I guess we likely have to live with it.
Windows is case-insensitive. You can use mixed case in the names, but as far as Windows is concerned "backup" and "Backup" are the same. You can't have "backup" and "Backup" subfolders in a main folder, and you can't have both "backup" and "Backup" network shares hosted from the same device.
- hamish_mcleanJun 09, 2016Aspirant
Thanks for your interest - a mystery here too.
Gone now (but not forgotten :-)
ReadyNas behaving nicely again - I've had a few over the years.
