raygear
Jan 13, 2018Aspirant
RN104 stuck on Boot Menu Mode - Normal after firmware upgrade
Hi all, I have updated my firmware via the web interface because Netgear said the new version 6.9.1 was available to install. Now I can't access the NAS and it's not vissible with RAIDar. Loo...
- Jan 26, 2018
Hi raygear,
Since the NAS is still not detected even without the disks, it is possible that the chassis already faulty. If you are the original purchaser of the NAS and if it is still under the hardware warranty, you may contact support. They can provide a replacement for your device.
JohnCM_S
NETGEAR Community Team
JohnCM_S
Jan 25, 2018NETGEAR Employee Retired
Hi raygear,
Can you try powering up the NAS without the disks and check if RAIDar will be able to detect the NAS?
Note: Please label the drives with their corresponding bay before you remove them to ensure that it still in the same order when you re-insert them.
JohnCM_S
