NasNard
Dec 05, 2015Guide
RN104 triggering vertical expansion in X-raid
Hi, I have an RN104 I just upgraded to 6.4.1. I had four 3tb drives and I swapped them for four 6tb drives. My drive space pre-swap was about 9tb, and I was expecting the new usable storage to be abo...
- Dec 09, 2015If anyone was wondering, after reviewing the logs, i determined it was faster to destroy everything and rebuild it to get the proper volume. Yay for backups.
Dec 05, 2015Guru - Experienced User
Is the array done syncing? If so, try restarting the NAS.
- NasNardDec 05, 2015Guide
As far as I can tell, the box is idle now. I've restarted twice since. Nothing is displayed in the front. Nothing displaying active in the UI (like nothing is in progress) and I have email notices that the last disk upgrade It has since changed from RESYNC to ONLINE.
Since then, I upgraded from 6.4 to 6.4.1 and restarted twice more.
I will restart again but this will be the third time.
- Sep 06, 2016Retired_Member
