BJB
Nov 05, 2013Aspirant
RN104-Utility to tell what it is processing/doing?
Greetings, My RN104 has run well but I hope this is the right section to as a nagging question I have. I am familiar with the reporting/log area where the readynas logs major events like making a sn...
Dec 02, 2013Guru - Experienced User
No installation is needed. On the RN102, ssh can be enabled from the services menu. top (like most other standard linux utilities) is already installed.
BJB wrote: StephenB,
Thanks for the suggestion....I am more than into tweaking things (I build my own PC's), however I would like to keep my RAID "stock" and a little nervous about installing some of the items required to run those utilities...
You do need something like putty installed on the PC to connect. In all ReadyNAS, the user name for ssh is "root", the password is the same as the NAS admin password.
