BJB
Nov 05, 2013Aspirant
RN104-Utility to tell what it is processing/doing?
Greetings, My RN104 has run well but I hope this is the right section to as a nagging question I have. I am familiar with the reporting/log area where the readynas logs major events like making a sn...
BJB
Dec 03, 2013Aspirant
StephenB wrote: I wouldn't worry about the activity light.
For performance testing, try NasTester (http://www.808.dk/?code-csharp-nas-performance). It only tests CIFS (windows file sharing) performance, but it should give you an overall idea on how the RN102 is functioning over the network. What router are you using?
Thanks, will check it out. I am using a D-Link DIR-860L router. It replaced a 5 year old D-Link DGL-4100 router and based on the numbers, if anything, should be faster?
I am currently using a standard windows share as it was working fine although I understand another share type might provide better performance.
Thanks again,
BJB
