dyvong
Sep 14, 2014Aspirant
RN104 vs NV+V2 read performance and disk storage variance
Hello, Recently, I experienced some traumatic experience with multiple drive failures. Luckily I was able to keep all my files intact on the NV+V2. In the process, I decided to get an RN104 to act ...
xeltros
Sep 14, 2014Apprentice
The RN104 should give you more than that, I've seen mine up to 95MB/s in read and 45MB/s in write. I tested it on wifi at 53MB/s no later than today.
Do you have antivirus, encryption or checksum enabled ? Did you defragment ? How much space have you left ? Do you have add ons enabled ? Is it rebuilding the array ?
Size on disk could be a difference in the block size for the partition. it is 4096 for the ext4 root partition on my 104, but I couldn't get the result for the data partition, if those are different then you may have wasted space due to a larger block size.
