cat71
Aug 30, 2015Aspirant
RN10400 6.2.5 no UI
Hello, run in truble after upgrading to 6.2.5. No login was possible, after reinstalling OS, i get an ssh login. "Attemd to reconect ..." First Problem was rootfs at 100%, after moving old loc...
mdgm-ntgr
Aug 30, 2015NETGEAR Employee Retired
71% is way too full. What have you out on there?
cat71
Aug 31, 2015Aspirant
mysql Database with more then 1.3GB Data.
i don't know witch apps use them.
Possible the squeesebox server. but i remove it 3 Month ago.
- StephenBAug 31, 2015Guru - Experienced User
You want to make sure the app data is stored on the data volume.
What apps do you have installed?
- cat71Aug 31, 2015Aspirant
can't look in UI, i have installed
- radius Server (only for testing)
- DNS UI (only for testing)
- squeezebox server (remove 3 month ago)
Im not sure, but i remove every app.
i install this DPK
- vim
- mc
- munin-node (removed)
- mdgm-ntgrAug 31, 2015NETGEAR Employee Retired
You should stop MySQL, move your database to the data volume and create a symlink to it on the OS partition.
