cat71
Aug 30, 2015Aspirant
RN10400 6.2.5 no UI
Hello, run in truble after upgrading to 6.2.5. No login was possible, after reinstalling OS, i get an ssh login. "Attemd to reconect ..." First Problem was rootfs at 100%, after moving old loc...
cat71
Aug 31, 2015Aspirant
mysql Database with more then 1.3GB Data.
i don't know witch apps use them.
Possible the squeesebox server. but i remove it 3 Month ago.
Aug 31, 2015Guru - Experienced User
You want to make sure the app data is stored on the data volume.
What apps do you have installed?
