francis6789
Oct 19, 2016Aspirant
RN10400 Error do_exit+8ec
Upgrade the firmware of my RN10400 version 6.5.1 to 6.5.2.
Error: + do_exit_8ec; Power LED flashes. Reboot menu, none of the functions is recognized,the USB port either, trials and several key disk f...
- Dec 22, 2016
Since the beginning, I said that with this error the USB port was not recognized, nor any function of the reboot.
Thus all that you say are not a solution.
The one here is thus that I found to end this exchange.
I found the way(means) to get back the contents of my disks.I bought a NAS of a mark having better reputation.
I put the RN104 in the trash can.
On the sector of the Private individuals, needs not to take them too much for imbecile ones.Goodbye.
Stepan1a
Dear all, i face the same problem some other's did report already: after firmware update i get the error message: "do_exit+8dc" when booting. tried to recover by USB with two different USB sticks and did fail, tried OS reinstall and even the factory reset - but only got the "do_exit+8dc" message again. what to do - any suggestion ? have 5TB of imporant data on the disks ............and no access at this point in time. thank you very much
francis6789
yes, the same.- Liam_R1Nov 14, 2016Aspirant
same here
- mdgm-ntgrNov 14, 2016NETGEAR Employee Retired
What happens when you boot off USB?
Do you get an error message on the LCD?
Or does the system boot off USB successfully and power itself off when done?
- corbo111ausDec 07, 2016Aspirant
MDGM i have sent you a pm regarding this
