francis6789
Oct 19, 2016Aspirant
RN10400 Error do_exit+8ec
Upgrade the firmware of my RN10400 version 6.5.1 to 6.5.2.
Error: + do_exit_8ec; Power LED flashes. Reboot menu, none of the functions is recognized,the USB port either, trials and several key disk f...
- Dec 22, 2016
Since the beginning, I said that with this error the USB port was not recognized, nor any function of the reboot.
Thus all that you say are not a solution.
The one here is thus that I found to end this exchange.
I found the way(means) to get back the contents of my disks.I bought a NAS of a mark having better reputation.
I put the RN104 in the trash can.
On the sector of the Private individuals, needs not to take them too much for imbecile ones.Goodbye.
francis6789
yes, the same.Liam_R1
Nov 14, 2016Aspirant
same here
- mdgm-ntgrNov 14, 2016NETGEAR Employee Retired
What happens when you boot off USB?
Do you get an error message on the LCD?
Or does the system boot off USB successfully and power itself off when done?
- corbo111ausDec 07, 2016Aspirant
MDGM i have sent you a pm regarding this
- mdgm-ntgrDec 07, 2016NETGEAR Employee Retired
Hi corbo111aus I have replied to your PM. There are a few things that can be tried to fix this, one of which is to try and do USB Boot Recovery to put 6.6.1 Beta on the system.
