Alein
Apr 18, 2017Aspirant
RN10400 Error do_exit+8ec
HI, I have a problem with my NAS. During FW upgrade I get an error after boot Error do_exit+8ec There is topic on the forum, but without solution. Every time I made USB recovery it is no...
mdgm-ntgr
Apr 18, 2017NETGEAR Employee Retired
This error suggests that the system has 6.6.0 on the internal flash and that the serial number is missing.
USB Boot Recovery to 6.6.1 should get it to a state where it will boot.
There is a way we can try to boot off USB into a debug state to troubleshoot rather than do the USB Boot Recovery. I'll send you a PM with details on this. I've found some systems which claim to fail to boot off USB, boot off a USB with these debug options.
If it won't boot off a USB key then there's two options:
1. If original purchaser from an authorised reseller contact support and if it's sitll under warranty they may decide to RMA it.
2. Another method to try to fix it. I can discuss what's involved with this via PM if required.
