owex
Dec 18, 2016Aspirant
RN10400 led blink/flash but nothing more :(
Hello, I just received a RN10400, it had no hdd inside and no power adapter . I buyed a power adapter and I putin a hdd When I connect the power adapter to the rn10400 ..... for couple of secon...
- Dec 25, 2016
I opened the NAS and fixed the display . Everything works now
thank you all
owex
Dec 19, 2016Aspirant
Thank you for your answer . Of course I didn;t buy it new . I buyed it like it is without trying it or smtg . it was a "what you see is what you get for this price" , and I buyed it .
I have a power adapter ( 12V 7.5Ah ) and as I said power button led is blinking . However power button is not working. no matter how often or long I press it .... it does not turn off the nas . when I am giving power is starts and that's it .
I'll get a hdd and zero it , then I'll put it inside , install RAIDar software and will let you know if any progress is made .
Thank you so far for your advices , I really appreciate it !
FramerV
Dec 20, 2016NETGEAR Employee Retired
Hi owex,
Just would like to verify if you were able to get a hard drive installed?
- owexDec 20, 2016AspirantFriday I will get a sata hdd I can do whatever I want with it , even if it gets broked ...not a problem .I'll zero the hdd and then try RAIDar under windows ( must install windows too ) .will update when I have all this done .Thanks for asking ....and feel free to give me any advice / suggestion .
RAIDar seems to "see" the machine .
power led is blinking continuosly , display is not visible / offline .
photo with raidar print screen, please advice what to do next ( except getting a hdd , zero it and drop it inside the machine )
- FramerVDec 22, 2016NETGEAR Employee Retired
Hi owex,
I apologize but I think you may really need to wait for the hard drives to further isolate the issue.
You could probably test the drives on your PC using a disk utility to confirm if they really have issues.
