owex
Dec 18, 2016Aspirant
RN10400 led blink/flash but nothing more :(
Hello, I just received a RN10400, it had no hdd inside and no power adapter . I buyed a power adapter and I putin a hdd When I connect the power adapter to the rn10400 ..... for couple of secon...
- Dec 25, 2016
I opened the NAS and fixed the display . Everything works now
thank you all
Dec 24, 2016Guru - Experienced User
owex wrote:
.Is there any source for a another working display ?
No. and if doesn't turn on briefly when you turn on the ReadyNAS then it is broken.
You likely will need to live without it. It's not strictly essential, but I do recommend that you maintain good backups (since the LCD is needed to navigate the boot menu, so troubleshooting will be harder without it).
But you should have backups anyway, since RAID really isn't enough to protect your data.
owex
Dec 25, 2016Aspirant
thank you all
- JennCDec 26, 2016NETGEAR Employee Retired
Hello owex,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards, - owexDec 26, 2016Aspirant
the connecting band from mainboard to display got interupted , also contacts was needed a cleaning .... once I fixed this problems , it worked
