Giftmischer
Jul 12, 2021Follower
RN10400 Nas / Resynchronisierung
Guten Tag . Ich benötige Hilfe. Ich ahbe eine 2. Festpatte in meinen Server gegeben und unabsichtich die Resynchronisirung aktiviert . Ich habe danach gewartet bis es fertig war. doch plötzlci...
Jul 13, 2021Guru - Experienced User
There's no way to cancel the synchronization (conversion to RAID-1), so if you really wanted a second volume you'll need to back up the NAS, do a factory default with the original disk in place, reconfigure it and restore the data.
Switch to flexraid before you insert the second disk again. That will give you an option to create a second volume. You make the switch by clicking on the XRAID control on the volume tab. If the control has a green stripe, then XRAID is enabled. If it doesn't, then you are in the flexraid mode.
