Doug6392's avatar
Jul 14, 2020
RN10400 - multiple failed disks or failed NAS hardware?
Using latest firmware and 4 WD Red 4TB HDDs in RAID5 configuration. NAS fell on its side (vacuuming accident) and overnight registered 2 failed disks and a dead drive. Am currently doing HD diagnostic on disks reported failed. Did factory default and one of 2 remaining disks reported failed. NAS is well out of warranty; before I invest in new HDDs, does this sound like the disks or the NAS failed? Thanks.
  • Doug6392 wrote:
    StephenB wrote:
    Doug6392 wrote:
    Tried rebooting with a known good HDD, and it rebooted into a legacy boot mode.
    Was this drive formatted?  If it was, then the NAS might be fine.
    Try the fast write-zero test in lifeguard - that will remove the partitions.  Then put it back in the NAS and power it up, and see if you get a different result.
    Impressive, StephenB ! I did as you suggested, and instead of booting into Legacy Mode, the NAS appears to be booting normally. I will go ahead and run the other tests as suggested (keeping my fingers crossed!) and post the result.
    Thanks very much.
    Final (hopefully!) update: after running through the tests suggest by Sandshark it appears that all drive bays are functioning properly. I added another old but still serviceable HDD (on which I first performed the quick erase as suggested by StephenB ), and on bootup the NAS is working to expand the existing JBOD. I can now go ahead with some confidence to begin to replace the failed HDDs. Thankfully, the last time I had a NAS hardware failure (2015, when I upgraded to my current NAS) I also learned the hard way that a NAS isn't a backup, so I have a complete backup of all the data lost in my sad vacuuming accident. :)
    Many thanks again for your prompt and capable assistance.
  • StephenB's avatar
    Sounds like the disks to me, but there could also be damage to the NAS.
    You could test the disks in a Windows PC with WD's Lifeguard software.  You can connect them either with SATA or a USB adapter/dock.
    • Doug6392's avatar
      Doug6392
      Guide
      Thanks. That's what I'm using to test the drives (in a dock), although it's painfully slow. I'm also running a memory test on the NAS at the same time; it should be finished first: I understand that if it doesn't finish in about 4 hours, then I may have my answer. (Hopefully they're not both borked! ;) )
      • Sandshark's avatar
        Sandshark
        Sensei
        Unfortunatly, the SATA backplane is also at risk, depending on what side of the NAS hit the ground.  Here is your best test:
        Using a known good drive (one of the old ones you've tested, or any you might have around), install just that drive and create a JBOD volume on it.  (This will, of course, erase any data on the drive, but I think you realize your volume is alreay toast.)  Then test it by adding a few files and accessing them.  Or use a speed test program.  Then power down, swap drive to the next bay, power up, and test again (you won't have to re-create the volume).  Repeat for bays 3 and 4.  Check the log for any signs of a problem (esp. mentions of ATA errors), and check the drive SMART, too.
        It's not a comprehensive test, but any backplane damage isn't likely to propagate, so it's pretty good at finding anything.
ProSupport for Business
