77PALE77
Jun 24, 2016Apprentice
RN10400 substitution of single disk with larger one
Hi guys, my RN10400 is configured with 3 1Tb hdd + 1 500Gb hdd. It is in X-RAID mode. I would like to change the 500Gb with a larger one (maybe 3Tb) using vertical expansion. Reading the manual (pg...
jaimeconde
Jun 24, 2016Aspirant
Hi, if you are going to replace the 500Gb with another 3Tb disk, I understand you only have to add only that disk.
But it the new disk is larger than the other three, this new one will wait for another new disk to fill the extra capacity. But you will have to wait to rebuild the first disk.
Thats what I understand, but I dont know...
- StephenBJun 24, 2016Guru - Experienced User
When you replace the 500 GB drive with a 3 TB one, then your volume will increase by 500 GB - 3 TB total (2.7 TiB).
Everything will work, but 2 TB of space will be unused. When you later replace one of the 1 TB drives with a 3 TB drive, then the volume will increase to 5 TB (4.5 TiB). At that point all the space on the disks will be used by the RAID array.
FWIW I recommend NAS-purposed (Seagate VN or WDC Red) or enterprise drives. The WD30EFRX or WD40EFRX are both suitable for your RN104. Upgrading with 4 TB drives is slightly more cost effective, so if the budget stretches to that you might want to consider using them instead.
- 77PALE77Jun 24, 2016Apprentice
Ok, it's almost clear.
But how do I change the disk?
Do I simply change it when NAS is off and then turn it on?Thanks a lot
A.Pallaro
