apikira
Jan 16, 2022Aspirant
RN202 bricked
Hi everyone! I've tried everything and got no solution, I explain... A week ago one of the disks (2nd bay) get offline, I thought was a good moment to upgrade the HDD from 4TB to 10TB. So, I bo...
Jan 17, 2022Guru - Experienced User
Maybe try testing the new disks in a Windows PC (powering down, and labeling by slot). While doing that, see if RAIDar finds the NAS (showing a "no disks" status).
- apikiraJan 18, 2022Aspirant
Thanks for your response.
No, RAIDar can't find the NAS even without the disks.
I just tried with only one small 500Gb disk, formated via PC:
- The lights seems OK (power and disk1 steady)
- Both ethernet ports LED links steady green- Last connection, 2 days ago when I perform a "Factory Reset"
- StephenBJan 18, 2022Guru - Experienced User
OK. Are you able to reach http://nas-ip-address/admin with the 500 GB drive installed? Use the real IP address of course.
Nope, no IP assigned.
As the image shows, the last connection to the router was 2 days ago while I'm perfoming a factory reset/OS reinstall.
If I scan the network the NAS doesn't show. Not even in the router "attached devices" list.
Thank you for your time, anyways.
- Mar 26, 2017Retired_Member
