apikira
Jan 16, 2022Aspirant
RN202 bricked
Hi everyone! I've tried everything and got no solution, I explain... A week ago one of the disks (2nd bay) get offline, I thought was a good moment to upgrade the HDD from 4TB to 10TB. So, I bo...
apikira
Jan 18, 2022Aspirant
Thanks for your response.
No, RAIDar can't find the NAS even without the disks.
I just tried with only one small 500Gb disk, formated via PC:
- The lights seems OK (power and disk1 steady)
- Both ethernet ports LED links steady green
- Last connection, 2 days ago when I perform a "Factory Reset"
Jan 18, 2022Guru - Experienced User
- Both ethernet ports LED links steady green- Last connection, 2 days ago when I perform a "Factory Reset"
OK. Are you able to reach http://nas-ip-address/admin with the 500 GB drive installed? Use the real IP address of course.
- apikiraJan 18, 2022Aspirant
Nope, no IP assigned.
As the image shows, the last connection to the router was 2 days ago while I'm perfoming a factory reset/OS reinstall.
If I scan the network the NAS doesn't show. Not even in the router "attached devices" list.
Thank you for your time, anyways.
- StephenBJan 18, 2022Guru - Experienced User
apikira wrote:As the image shows, the last connection to the router was 2 days ago while I'm perfoming a factory reset/OS reinstall.
That image is from your router UI?
You are seeing green status on both ethernet ports - do you have bonding set up? Have you tried disconnecting one of the two ports?
- apikiraJan 20, 2022Aspirant
Hi, Stephen. Thanks for your time.
Yes, the image is from my router UI.
The original configuration used to be in bonding, but after many factory resets, HDD replacements and OS reinstall I don't think the original configuration has to do something. Anyways I've tried with only one port and was the same result.
Regards.
- Mar 26, 2017Retired_Member
