Max_Marthini
Jan 24, 2019Aspirant
RN204 - data DEGRADED and gets a message of "Admin page is offline"
I received the following message on my ReadNAS 204: "data DEGRADED" and I suspect that one of the disks may have crashed. My problem is that I cannot access to the admin page. I only get the message ...
JohnCM_S
Feb 08, 2019NETGEAR Employee Retired
Hi Max_Marthini,,
Do you still need assistance on this issue? If you were able to download the logs, you can upload it to a file sharing site then PM me the download link so we can investigate it.
JMaclean62
Jul 12, 2022Aspirant
Hi,
I had this same problem, but I decided to just start over with reformatted drives. Trouble is that it failed during reformatting. What is the best way of going about "rebuilding" the whole drive?
Thanks,
Jeff
- SandsharkJul 12, 2022Sensei
If it failed during reformatting, then it's likely you have a bad drive. You can use the NAS drive test, but using a PC with each drive attached internally or via a USB dock and vendor tools is more informative.
