Yashii
Oct 21, 2017Aspirant
RN204-100NES. Boot issue
Hi I am currently running a NETGEAR ReadyNAS 204 4-Bay Network Attached Storage Diskless (RN204-100NES). All bays are occupied. I bought it February of 2016. My problem is my system will not c...
Oct 22, 2017Guru - Experienced User
Do you know what firmware you are running?
Yashii
Oct 22, 2017Aspirant
I believe it is at least 6.7.4
- StephenBOct 23, 2017Guru - Experienced User
Thx. And the problem didn't happen right after a firmware update?
- YashiiOct 23, 2017AspirantNo, it did not. It had been running until the reboot.
But I remember why I looked at my error log. I couldn't access it using readycloud.
I found this link:
https://kb.netgear.com/000038517/Why-can-t-I-access-my-ReadyNAS-system-using-ReadyCLOUD
I followed the instructions and regained readycloud access. I rebooted. That's when this problem began.- StephenBOct 23, 2017Guru - Experienced User
The simplest approach is to use paid netgear support (my.netgear.com). Ask for per-incident support - which should be less than $100 USD.
Another way is to do a factory reset, and rebuild the NAS. If you have a current backup, that's cheapest way to go, and it will clear out any corruption in the OS partition and/or the data volume.
Do you have experience using linux shell commands? If so, it is possible to boot the system in a tech support mode, and look at the filling OS volume.
