Yashii
Oct 21, 2017Aspirant
RN204-100NES. Boot issue
Hi I am currently running a NETGEAR ReadyNAS 204 4-Bay Network Attached Storage Diskless (RN204-100NES). All bays are occupied. I bought it February of 2016. My problem is my system will not c...
Yashii
Oct 23, 2017Aspirant
Thanks for your information.
No; no experience with Linux shell commands. Are there any instructions or information sources I can use as a guide if I wanted to try that route?
Thanks again.
Oct 23, 2017Guru - Experienced User
There is no guide, and generally I don't recommend folks with no linux experience to attempt it. Paid support is a better path if you want to preserve your data, the factory reset is better if you don't care about that.
Basically you need to manually mount the OS partition, and, sort out where the space is going (the OS partition usually is ~20% full, not over 80%). Then you have to clean out files that don't belong there.
- YashiiOct 23, 2017Aspirant
Thank you for your information.
