MichelTiberghi
Dec 27, 2020Aspirant
RN212 Disk 2: Volume Creation Failed
Hi, I recently bought a RN212 and started with one Seagate Ironwolf 4T ST4000VN008, which should be supported. It started with no problems. Alas, last week I bought the same disk: Seagat...
- Jan 04, 2021
MichelTiberghi wrote:
So I'll have to send back my disk
That makes sense, since you can't test it in a PC. I do suggest picking up a USB adapter/dock - the adapters are pretty inexpensive, and they are useful when you need to test a disk.
MichelTiberghi
Dec 28, 2020Aspirant
Hi Sandshark Sandshark
I feel really dumb, I think i insert the disk hot, while the nas was still on and the xraid on.
Can I still recover the disk?
Dec 28, 2020Guru - Experienced User
That does no damage, and in fact is what we normally recommend. Though since XRAID was on, the system should have created a RAID-1 array on the two disks.
Can you download the log zip file, and then copy/paste the contents of mdstat.log into a reply?
- MichelTiberghiDec 28, 2020Aspirant
Hi
this is the log:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid1 sda3[0]
3902168832 blocks super 1.2 [1/1] [U]
md1 : active raid1 sda2[0]
523712 blocks super 1.2 [1/1] [U]
md0 : active raid1 sda1[0]
4190208 blocks super 1.2 [1/1] [U]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Thu Feb 13 05:12:53 2020
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 1
Total Devices : 1
Persistence : Superblock is persistentUpdate Time : Mon Dec 28 14:39:23 2020
State : active
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0Consistency Policy : unknown
Name : 6da64c9f:0 (local to host 6da64c9f)
UUID : 8ef37b25:c27d2f46:74f63c94:a78d288f
Events : 9Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
/dev/md/1:
Version : 1.2
Raid Level : raid1
Array Size : 523712 (511.44 MiB 536.28 MB)
Used Dev Size : 523712 (511.44 MiB 536.28 MB)
Raid Devices : 1
Total Devices : 1
Persistence : Superblock is persistentUpdate Time : Mon Dec 28 08:22:24 2020
State : clean
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Name : 6da64c9f:1 (local to host 6da64c9f)
UUID : 887766c4:99261c50:8486d313:e27895ac
Events : 2Number Major Minor RaidDevice State
0 8 2 0 active sync /dev/sda2
/dev/md/data-0:
Version : 1.2
Creation Time : Thu Feb 13 05:13:20 2020
Raid Level : raid1
Array Size : 3902168832 (3721.40 GiB 3995.82 GB)
Used Dev Size : 3902168832 (3721.40 GiB 3995.82 GB)
Raid Devices : 1
Total Devices : 1
Persistence : Superblock is persistentUpdate Time : Mon Dec 28 14:39:00 2020
State : clean
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Name : 6da64c9f:data-0 (local to host 6da64c9f)
UUID : d9a97abf:710c5ee0:6afca304:863c9e43
Events : 3Number Major Minor RaidDevice State
0 8 3 0 active sync /dev/sda3
