MichelTiberghi
Dec 27, 2020Aspirant
RN212 Disk 2: Volume Creation Failed
Hi, I recently bought a RN212 and started with one Seagate Ironwolf 4T ST4000VN008, which should be supported. It started with no problems. Alas, last week I bought the same disk: Seagat...
- Jan 04, 2021
MichelTiberghi wrote:
So I'll have to send back my disk
That makes sense, since you can't test it in a PC. I do suggest picking up a USB adapter/dock - the adapters are pretty inexpensive, and they are useful when you need to test a disk.
MichelTiberghi
Jan 04, 2021Aspirant
Hi Stephen,
When I format the disk, I works, but with creating a volume it fails
in the system.log it says, disk may be damaged:
error 5; strange be
Jan 04 12:06:46 GHENTlemensBBQ readynasd[2112]: adding partition failed [5]
Jan 04 12:06:46 GHENTlemensBBQ readynasd[2112]: Found sdb is not a member of swap
Jan 04 12:06:46 GHENTlemensBBQ readynasd[2112]: Partitioning failed! [4]
Jan 04 12:06:46 GHENTlemensBBQ readynasd[2112]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Unable to save backup partition table! Perhaps the 'e' option on the experts';menu will resolve this problem.;Warning! An error was reported when writing the partition table! This error;MIGHT be harmless, or the disk might be damaged! Checking it is advisable.;
So I'll have to send back my disk, I think
Jan 04, 2021Guru - Experienced User
- MichelTiberghiJan 04, 2021Aspirant
Hi Stephen,
I'll absolutely buy one to be sure!
Thanks for the tip!
I'll test it and then see if it's broken or not,
Thank you so much for your help!
