AngelG
Sep 30, 2018Guide
rn212 OS 6.6.0 BackUP job not working
I have RN212 with OS 6.6.0 and can't start a backup job from a Windows 7 PC. My NAS and PC are in the same workgroup. I have a shared folder with full access to everyone. While setting a backup job t...
- Oct 01, 2018
It looks to me like the issue is in on the PC, not the NAS.
Oct 01, 2018Guru - Experienced User
Perhaps try using your Windows username/password in the backup job.
There is a difference between network permissions and file permissions. It sounds like you have the network permissions on the PC set to allow access, but perhaps the file permissions aren't.
- AngelGOct 01, 2018Guide
OK. I will play with user rights on NAS.
- StephenBOct 01, 2018Guru - Experienced User
- AngelGOct 04, 2018Guide
You are absolutely right StephenB. Thanks for the advice.
The problem was in the PC. Something is wrong with User rights. I have tested the same NAS with different PC and it works perfect. I even have attached my HDD as secondary HDD to other PC and successfully have Backuped the foders I needed to Backup.
Now I have to install from scratch my Windows 7 Pro 64-bit because can't diagnose the user access problems. With new installation there wont be any problems.
- Apr 26, 2021Retired_Member
