AngelG
Sep 30, 2018Guide
rn212 OS 6.6.0 BackUP job not working
I have RN212 with OS 6.6.0 and can't start a backup job from a Windows 7 PC. My NAS and PC are in the same workgroup. I have a shared folder with full access to everyone. While setting a backup job t...
- Oct 01, 2018
It looks to me like the issue is in on the PC, not the NAS.
Oct 01, 2018Guru - Experienced User
Perhaps try using your Windows username/password in the backup job.
There is a difference between network permissions and file permissions. It sounds like you have the network permissions on the PC set to allow access, but perhaps the file permissions aren't.
AngelG
Oct 01, 2018Guide
OK. I will play with user rights on NAS.
- StephenBOct 01, 2018Guru - Experienced User
- AngelGOct 04, 2018Guide
You are absolutely right StephenB. Thanks for the advice.
The problem was in the PC. Something is wrong with User rights. I have tested the same NAS with different PC and it works perfect. I even have attached my HDD as secondary HDD to other PC and successfully have Backuped the foders I needed to Backup.
Now I have to install from scratch my Windows 7 Pro 64-bit because can't diagnose the user access problems. With new installation there wont be any problems.
- Apr 26, 2021Anonymous
