doctorcat
Jun 23, 2014Aspirant
rn2120 - freezes! help!!!
hello. Need help. I do not understand rn2120, constant freezes if read/write speed than 30-40 MBps. On the shelves have to wheel 4 VM, but I can not run and three. is the last version 6.1.8 ...
doctorcat
Jun 24, 2014Aspirant
Skywalker wrote: 6.1.9-RC5 gives you the ability to configure the sync write policy on iSCSI LUNs. This allows you to switch sync writes to disabled, to match the behavior of our earlier products and competitors' offerings. Our default is to flush the disk write caches when the initiator asks for a sync write, which is probably what is causing your slowness, since some initiators/workloads ask for sync writes *a lot*.
Installed the beta version of the firmware, unfortunately it did not solve my problems.
Just noticed that whenever the device is reset, it starts to rebuild the raid.
- Jan 17, 2024Retired_Member
