AclandBurghley
Jun 06, 2016Aspirant
RN2120 iSCSI Create LUN failed
Dear All, Max LUN size available is 9.81TB When I create this, nothing happens. When I create a 5TB LUN, it creates it perfectly fine. If I attempt to expand this LUN to 9.81TB, it gives me an ...
- Jun 06, 2016
AclandBurghley wrote:
Any idea on how I can create a single LUN at 9.81TB in size? If not, why is there a limit?
There is an 8 Tib limit on all ARM-based OS6 NAS(including the RN2120v2). Netgear lists that as a limitation here: http://kb.netgear.com/app/answers/detail/a_id/29938/~/readynas-os-version-6.5.0 (deployment note 6)
I don't know why that limit exists, it seems arbitrary in a device that can host a 32 TB RAID-0 volume.
Jun 06, 2016Guru - Experienced User
AclandBurghley
Hi StphenB,
Thank you for this update. I should have looked a little harder.
Regards...
