jangoloti
Jan 25, 2016Apprentice
RN2120 "Problem connecting to server" message at each Mac start
Dear all, I get everytime I start my Mac the following pop-up: There was a problem connecting to the server “********”. The server may not exist or it is unavailable at this time. Check the ...
mdgm-ntgr
Jan 25, 2016NETGEAR Employee Retired
Which other services are you running?
Are you running any apps?
- jangolotiJan 26, 2016Apprentice
Not at the moment the message appears. Some background OS X services maybe, but nothing special.
- StephenBJan 26, 2016Guru - Experienced User
He's asking about services/apps on the NAS, not the PC.
- jangolotiJan 30, 2016Apprentice
Ooops..
No apps on the RN, only the Antivirus plus, and at the beginning I did not have it and it was the same.
I think anyway it is an issue with the Finder server options: I cannot remove the NAS from the servers that connect (or try to connect) at start, it is three times there (SMB+AFP+other) and one may not be properly configured.
The procedure to remove is quite complicated it seems. Anybody familiar with MAC OS X there?
