jangoloti
Jan 25, 2016Apprentice
RN2120 "Problem connecting to server" message at each Mac start
Dear all, I get everytime I start my Mac the following pop-up: There was a problem connecting to the server “********”. The server may not exist or it is unavailable at this time. Check the ...
mdgm-ntgr
Jan 25, 2016NETGEAR Employee Retired
Which other services are you running?
Are you running any apps?
jangoloti
Jan 26, 2016Apprentice
Not at the moment the message appears. Some background OS X services maybe, but nothing special.
- StephenBJan 26, 2016Guru - Experienced User
He's asking about services/apps on the NAS, not the PC.
- jangolotiJan 30, 2016Apprentice
Ooops..
No apps on the RN, only the Antivirus plus, and at the beginning I did not have it and it was the same.
I think anyway it is an issue with the Finder server options: I cannot remove the NAS from the servers that connect (or try to connect) at start, it is three times there (SMB+AFP+other) and one may not be properly configured.
The procedure to remove is quite complicated it seems. Anybody familiar with MAC OS X there?
- StephenBJan 30, 2016Guru - Experienced User
I'm not, but others are.
If you have the AntiVirus service running on the NAS, disable it on system->settings->services. Note this is the AV service itself, not the AV plus app. It has a serious performance issue in 6.4.1 and 6.4.2 beta. It might not be related to your immediate problem, but still Netgear is recommending that it be disabled for now.
