nativevml
Jun 21, 2017Aspirant
RN2120 v2 6.7.4 Management service is offline
Hi There, first timer here so apologies for the terminology, I have a RN 2120v2 with FW: 6.7.4, the status is Management service is offline, my drives are healthy and I can browse the shares ...
Marty_M
Jun 21, 2017NETGEAR Employee Retired
Hello nativevml,
Does the raidar still detect the NAS on the network? If it does then there is a way to download the logs, from the logs we can verify what may have cause this behavior of he NAS.
I will send a PM for the logs.
Welcome to the community!
Marty
NETGEAR Community Team
nativevml
Jun 22, 2017Aspirant
Hi Marty,
Thanks, Yes Raidar still detects the device and runs diagnostics as well as downloading the logs,
I have replied to you PM.
Thanks again
- Marty_MJun 22, 2017NETGEAR Employee Retired
Hello nativevml/JoesCat,
To be on the safe side since both you have access to the shares, I would recommend backup the data specially the one's you used for production. Please check if you NAS's are still under phone support warranty since the concern might require back end access to the NAS for a fix.
Regards,Marty
NETGEAR Community Team- nativevmlJul 03, 2017Aspirant
Marty_M wrote:Hello nativevml/JoesCat,
Regards,Marty
NETGEAR Community TeamDUDE!!! I did the https://x.x.x.x/fwbroker and it worked!!!! thank you :smileyvery-happy:
- Jun 10, 2022Retired_Member
