atsob
Feb 03, 2021Guide
RN214 - Volume data is Degraded almost every after reboot
Hello all I'm happy owner of RN204 with 4 x WD40EFRX for some years and then I bought two used RN214. First RN214 (NAS1) is with 3 x WD121KRYZ (all 3 new disks) and the second RN214 (NAS3) is wi...
Feb 03, 2021Guru - Experienced User
I'd start by downloading the log zip file from the web ui for both NAS. Look for btrfs and disk errors in system.log and kernel.log. You can ask the mods ( JohnCM_S and Marc_V ) to analyze the log zip for you - but don't post a download link here. Instead, send them a private message (PM) using the envelope icon in the upper right of the forum page. Include a link to this thread, and also download links (google drive, dropbox, etc) to the full log zips.
Also, try running the disk test from the volume settings wheel.
Power might be an issue here. The WD121KRYZ will use more power than the WD100EFAX. If the WD100EFAX system seems to show the symptoms more, you could try swapping the two power adapters.
atsob
Feb 03, 2021Guide
Thank you Stephen
I have sent PM with the logs zip to Marc & John.
About Disk Test recommendation, I will try to execute as long as Resyncing is completer (ETA 26 hours...)
Thanks
Angelos
