edkedk
Jun 17, 2019Tutor
RN214 file system read-only (again)
It seems I'm extremely unlucky with this device because this is not the first time a file system error appears (cf. https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN204-repeated-fil...
Jun 17, 2019Guru - Experienced User
edkedk wrote:
Some weeks ago I replaced a disk that started to develop bad sectors.
Ok. And that resynced ok?
Perhaps enable ssh, and enter
# smartctl -x /dev/sda # smartctl -x /dev/sdb # smartctl -x /dev/sdc # smartctl -x /dev/sdd
and look for saved errors for the drives.
For example, something like this:
Error 12 [11] occurred at disk power-on lifetime: 36166 hours (1506 days + 22 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 0c 27 df 40 40 00 Error: UNC at LBA = 0x0c27df40 = 203939648 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 80 00 c8 00 00 0c 27 df 40 40 08 1d+08:15:46.204 READ FPDMA QUEUED 60 00 08 00 c0 00 01 06 34 36 98 40 08 1d+08:15:46.163 READ FPDMA QUEUED 60 00 80 00 b8 00 00 0c 27 e4 40 40 08 1d+08:15:46.146 READ FPDMA QUEUED 60 00 80 00 b0 00 00 0c 27 e9 40 40 08 1d+08:15:46.123 READ FPDMA QUEUED 60 00 80 00 a8 00 00 0c 27 ee 40 40 08 1d+08:15:46.094 READ FPDMA QUEUED
edkedk
Jun 17, 2019Tutor
Yes, resync completed without any error.
