edkedk
Jun 17, 2019Tutor
RN214 file system read-only (again)
It seems I'm extremely unlucky with this device because this is not the first time a file system error appears (cf. https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN204-repeated-fil...
edkedk
Jun 17, 2019Tutor
Yes, resync completed without any error.
edkedk
Jun 17, 2019Tutor
Actually, the error I mentioned in the older thread I linked in the first post happened on the other RN214 device we have in the network...
The disk was replaced in the one this thread is about.
- edkedkJun 18, 2019Tutor
I have run the smartctl commands. On two disk there are 1 and 3 reallocated sectors. On sdd there is this error log:
Error 1 [0] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 84 -- 41 00 00 00 00 00 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 08 00 78 00 00 00 00 01 b8 40 08 00:00:32.826 READ FPDMA QUEUED 60 00 08 00 70 00 00 00 00 01 b0 40 08 00:00:32.826 READ FPDMA QUEUED 60 00 08 00 68 00 00 00 00 01 a8 40 08 00:00:32.825 READ FPDMA QUEUED 60 00 08 00 60 00 00 00 00 01 a0 40 08 00:00:32.825 READ FPDMA QUEUED 60 00 08 00 58 00 00 00 00 01 98 40 08 00:00:32.825 READ FPDMA QUEUED
- StephenBJun 18, 2019Guru - Experienced User
Error 1 [0] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) Error: ICRC, ABRT at LBA = 0x00000000 = 0
It looks like that happened when the disk was initially powered up. Did you put it into the NAS right away, or did you connect it to a PC and test it first?
It's related to the communication between the NAS (or computer) and the drive, so it could simply be a poor connection when first plugged in. I don't think this error is concerning (and don't see how it would make your system read-only, since it happened before the drive was added to the array).
The other drives with the reallocated sectors might be part of the puzzle though, and probably should be tested.
