freakout
Mar 09, 2024Star
RN214 internal power supply failure
Hi all, My second ReadyNAS (RN214) died recently after five years of always-on use. Same thing that killed my previous one - failure of the internal power supply. I've had some awful problems...
- Mar 10, 2024
Recovery is now in progress, humming along the LAN to my new QNAP at a blistering 75MB/s, ish. Not sure if that speed limit is due to the resources I allocated to the VM (bridged adapter, 2 CPUs, and 2GB of RAM) or some other limitation happening on the network. But whatever, at least it's working! The VM recognized the raw drives instantly and booted just like real hardware would. Even reverted to my old login credentials.
Sandshark, I have 4 x 8TB Seagate Ironwolf Pros in RAID 5, for 20TB available space. I'd offer a minor tweak to the instructions that you posted:
1) Firstly, Windows users may encounter problems getting vboxmanage.exe to actually mount the raw drives, getting an ACCESS ERROR message (or something like that), as I did at first. This is likely due to a permissions problem with VboxSVC.exe - go into the Properties menu and set it to run as administrator. Run vboxmanage.exe and VirtualBox itself as admin, too. Once I did this it all worked smoothly.
2) Second, the createrawvmdk command has now been deprecated and VirtualBox recommends you don't use it. The new approved method for mounting a raw drive is:
VBoxManage.exe createmedium disk --filename nas1.vmdk --format=VMDK --variant RawDisk --property RawDrive=\\.\PHYSICALDRIVE1
Thanks again for posting your initial guide - I likely wouldn't have my data back without it!
freakout
Mar 10, 2024Star
Thanks Sandshark. Fortunately, a helpful YouTuber uploaded the image to Google Drive for me. There's a link in his video description here, if anyone else has this issue: https://www.youtube.com/watch?v=l1wnpyGb4cA
I've successfully booted the VM now and have access to the GUI. I'll make an attempt at connecting the drives for recovery tomorrow (it's 0100 here!). Will update this thread to help out others who may face the same problem as the ReadyNAS hardware that's still out there gets older.
Sandshark
Mar 10, 2024Sensei
Glad you got it worked out.
How large are your drives? One thing I never did is try to determine if there was a limit to the drive size, just as there is a limit to the number of drives. So let us know if you have success.
- freakoutMar 10, 2024Star
- SandsharkMar 11, 2024Sensei
I think the slow speed can be attributed to the fact that the drives are still going through the VBox virtual drive interface, though they are in raw mode. But speed isn't the main consideration here, so it sounds like a success.
I assume from the fact that the vboxmanage command has been depreciated that you are running it on VirtualBox V7. Good to know it still works with that, though I had no reason to think it wouldn't.
Whether or not you need to make the permission changes depends on the main security settings you have on your computer. If you have them set to prompt for admin permission, then the changes shoudn't be needed. I likely did run vboxmanage from an admin command prompt and didn't think to specify that.
I thank you for bringing attention back to this free method of data recovery that does not require knowledge of Linux. If a volume is corrupted, it's not going to help, but many may find themselves in your shoes as ReadyNAS get older.
- saudadeMar 11, 2024Apprentice
I see the virtual image is OS 6.6. Did you upgrade the firmware? If so to what version?
Just curious. I "installed" it using VMWare Workstation, got it to run no problem, but couldn't update the firmware to anything less that 6.10.10 using the "manual" method from the GUI. It kept flagging I needed to update to 6.10.10. If I clicked OK, the auto-upgrade worked fine.
I also used VBox 7 and got a similar behavior.
Again, I was just tinkering with the image to see the difference from my Duo V1 so no real issue here.
Thanks
I've kept mine updated through the years and am currently on 6.10.9. I'm not sure why the manual option won't work, but 6.10.10 is fine for what you're doing.
On a real NAS, the flash automatically updates to the version on the drives if it's newer. Maybe the VM doesn't do that, and it was saying you needed to update to the same version that was on the drives.
